It no work because this doesn't have DMI information, I need a backup. Can you help me with this?Bios - msi gl63 8se msi gl63 8sek ms-16p7 -ver e16p7ims.111 ec-ver 16p7ems1.108 bios
msi gl63 8se msi gl63 8sek ms-16p7 -ver e16p7ims.111 ec-ver 16p7ems1.108 16 mbdr-bios.com
I am not sure but i send you some photos for that you seeboard model is ms-16p7 ?
Of course, the board model is ms-16p7check under all stickers and also under heat sink
The BIOS work spectacular (it solve the freezes randoms while run Operating System or when I am in the bios). Now, I have another problem, the GPU no work, for example, when I run a video game, the game run very slow or not work (before of all this, it worked good), I saw the task manager and the use of GPU is 0∼1 percent... Conclution: the GPU isn't work correctly, I think that the problem could be solve if I flash bios of GPU.the bios is working OK
please check all things carefully
What do you think?
Is important to flash EC bios? I don't have tools for thisjust try the new file
I think that i can use EcFlashWin created for MSI. Is it right?just try the new file
i don't knowI think that i can use EcFlashWin created for MSI. Is it right?
seems this problem is not related to biosIt don't work yet. The GPU give picks jumps sometimes and after that go to 0 percent
Do you have a vbios nvidia rtx2060 of MSI for test?seems this problem is not related to bios
you need to check all parts of motherboard
send backupDo you have a vbios nvidia rtx2060 of MSI for test?
octavio , Salimeh Bolboli , binarcos , user16990 , Vahab Hemmati , arraz , destinycenter , user50630 , endurance albert
